Gas tank refurbishment 1940 LaSalle
Started by scott c. 40 LaSalle, May 16, 2015, 12:46:34 AM
scott c. 40 LaSalle
Hi
I have a 1940 -52.  Just removed the gas tank and plan to get it refurbished locally.
The drain plug / nipple was leaking and over time appears to have "varnished" on the bottom, around the drain area.
Any advice?  Replace sender unit while it's out?  What to use to replace plug? Parts?  Other than a dent (no creasing) the tanks seems to be in good to great shape. What does this process usually / or should involve and approximate cost.  Thanks for your advice and suggestions.  Cheers scott in Red Deer
Jay Friedman
My '49's gas tank needed some work as it was dirty inside and something was wrong with the sending unit causing the needle to show empty when the tank was half full.  There was also something wrong with the hose coupling between the filler tube and the tank itself, causing a leak when the tank was full.  Nothing major, but rather than fix this tank, I was talked into buying a new tank, including a new hose and sending unit, from Kanter in Boonton NJ for about $500.  It was a good decision as the aftermarket tanks are well made, as is the new sending unit.  It was an expensive fix but all the old problems have been completely cured.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
scott c. 40 LaSalle
thanks - I will look into that as an option.
