More questions on my 1957 Series 62
Started by Cadillac Jack 82, October 01, 2015, 11:07:21 AM
Cadillac Jack 82
Hi folks...a few more questions for all of those here who own/have owned a 1957 Caddy.  They are:
1.  Do I have to remove the back seat to remove the package shelf in the rear?  I found the reason my rear speaker doesn't work...its original and completely destroyed due to heat.  It needs to be replaced by removing the package shelf since the screws come in from the top.
2.  Horn ring is on the loose side.  In a previous post someone mentioned adjustment screws on the back which I have failed to locate.  Where exactly are these adjustment screws?
3.  Right hand auto cancel works but the left hand doesn't work 100% of the time (more like 10%).  Is this an indication the turn signal indicator mechanism needs to be replaced or adjusted?
Thanks!
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Jon S
Quote from: 57shark82 on October 01, 2015, 11:07:21 AM
Thanks!
1.  You may get lucky and be able to remove the retining nuts from the bottom.
2.  There are two allen head screws between the chrome bezel and the painted spoke for adjustment.
3.  Indicator mechanism probably on the way out.
Jon
CLC Member Number 24786
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Cadillac Jack 82
Thanks but going back to #2...how do I access those allen screws?  Also going back to #1 I still need to remove the original speaker which is situated under the package tray.
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Jon S
Quote from: 57shark82 on October 01, 2015, 11:18:58 AM
Allen screws are accessable from the rear of the steering wheel. Shine a flashlight at the back of the chrome bezel and you will see two allen heads close to the center emblem. Be careful adjusting them as the piece they screw into is pot metal.
The speaker should be accessible from the trunk if it is factory installed.
Jon
1981 Corvette
2004 Mustang GT
Walter Youshock
Where's your shop manual...  gotta get one.
The skewed horn ring could also be contributing to your turn signal issue.  I remember oiling the canceling cam bushings on my car years ago.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Jack 82
Walter...its on my list of things to get.  I've always had shop manuals for my cars I've just not picked one up for this car yet.
I'll take a look at the steering wheel when its not raining cats and dogs outside.  Hopefully this hurricane drifts out to sea and takes away all this damn rain!
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Cadillac Jack 82
Walter:
    Would it be too much to ask to take a photo of the area where you can adjust the horn ring?
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Walter Youshock
If you look behind the wheel spokes, you'll see a notch in the plastic about an inch or so long.  They're in those notchrs.
If I remember, removing the horn ring exposes the turn signal return cam spring.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Jack 82
Alright I'll give it a shot this weekend if the weather cooperates
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
