1967 429 flexplate
Started by Coupe.67.Deville, December 22, 2015, 11:45:25 PM
Coupe.67.Deville
Im looking for a flexplate for my 1967 coupe deville , witch i believe is a 166 tooth ive found some that seem like thay should work but id rather not find out the hard way does anyone know why the later 68 model is different than 67?
cadillactim
The 1968 engine is totally different. Only 1965-67 flywheels will work.
Tim Groves
Coupe.67.Deville
I know the 68 472-500 motor is different just didnt know what the difference in the flexplates where, i figured id have to get 429 flexplate just didnt know if anyone had figured out one that would fit ,like my 66 lemans also fit many other engine types,ive search and found this b&m multiple times but i figured it was a mistake
