1937 Cadillac Series 60 Rear Axle Outer Bearing
Started by jackworstell, February 25, 2016, 07:45:53 PM
jackworstell
      To replace the outer bearing on the rear axle on a 1937 series 60 Cadillac:    is it as simple as pressing the old bearing off and pressing the new bearing on ???
Jack Worstell   #7558
Yes, after you have pulled the drum, disconnected the brake line, undone 4 bolts to remove the bearing cover and back-plate then pulled out the axle shaft.
