74 devill rear axle driver side... stem or grease connection???
Started by lentel, April 24, 2016, 10:30:55 PM
lentel
on my 74 deville rear axle on the driver side along the top is some type of stem or grease connection.. I dont  know what it is .. anyone have any idea?
thanks for all help
Bob Hoffmann CLC#96
lentel
thanks bob....i noticed it is somewhat greasy... is that normal for it to be like that
thank you again for your response
Bob Hoffmann CLC#96
It shouldn't be leaking grease. You might want to clean it off with some solvent, make sure its not plugged & check it occasionally.
Bob
lentel
thanks bob... would that be differential oil comming out? what is there is black and thick and dirty like bearing grease like but really dirty
thanks you again
