1953 series 62 low compression.
Started by gary griffin, April 23, 2016, 10:53:09 AM
gary griffin
I have a friend who is preparing to sell a pretty decent car with very low compression in 3 cylinders. We used to pour a can of STP through the carburetor very slowly while keeping the engine revved  up and that usually freed the rings. This car was last licensed in Washington in 1994.
Gary Griffin
Gary,
If you are asking "how to fix the low compression", you first need to determine the cause.  How low is the compression? It could be the valves or the rings.  First with a warmed up engine, do a dry/wet compression test, adding a couple teaspoons of oil after the dry test to see if the compression comes up.  Then a leak down test will most likely give  an audible signal as to where the leaks are.
Bobby B
Quote from: "Cadillac Kid"  Greg Surfas 15364 on April 23, 2016, 11:09:19 AM
Gary,
Exactly…Determine weather it's leaking past the rings or valves.
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
