Trim pieces raised/cup washers/spacers ??
Started by J. Gomez, October 17, 2016, 05:38:13 PM
J. Gomez
Ok folks I give up after searching Google for the correct name and multiple other sites for bolts/nuts, specialty sites, body suppliers, general GM parts suppliers, etc. I’m at a lost.  >:(
I need a few of these type of raised/cup washers/spacers which are used on the chrome pieces specially the larger one with the threaded studs.
Any one knows of a source or the correct name?
I was able to make three to finished the rear RH side door trim, but it is time consuming and I rather get them is they are available.  :(
No, I do not want to use regular or fender washers and stacked them together, some of the areas where these go a hard to reach and handling several of the washers and the nut would be a pain.  ;)
J. Gomez
CLC #23082
55 cadi
Mr. Gomez,
Try Ace hardware/true value,  they have a large aisle of odd and hard to find parts, I have found a few things there for the Cadillac.
That's where I found correct rivets for the vacuum manifold, they have chromed screws, all kinds of spacers and bushings, even rubber bump stops that work for factory style.
Jason
1955 Cadillac sedan series 62
1966 mustang convertible w/pony PAC, now in Sweden
2005 Cadillac deville
Ralph Messina CLC 4937
That's what I'd call a "speed nut". They are characterized by the smaller star shaped hole in either sheet metal  or machine thread dimensions...eg: No.8 sheet metal screw or 10 - 24 coarse. The larger outside diameter can be built up with a washer. Try Restoration Specialties" : http://www.restorationspecialties.com/
They are very helpful and have everything in  fasteners.
2018 GMC Yukon
J. Gomez
Jason,
Thanks for the tip; I did check my local AC hardware and no luck.  :(
Ralph,
Found they are call “cup washer” and are use on several GM models to hold the trim pieces as the post where the stud screw in extends inside the panels. I was also provided a GM (Chevy site) which has them.  8)
Thanks everyone
J. Gomez
CLC #23082
How about sharing a link to that site!  Believe it or not Jaguar used those way back when and I could use some.  Thanks.
Quote from: Ralph Messina CLC 4937 on October 17, 2016, 08:33:46 PM
Ralph, I'm not so sure: the indentations are more like a spring washer to avoid that the nut will get lose with vibrations.
6262
1962 Cadillac Series 62
1965 Pontiac Bonneville
Steve Passmore
If they were a speed nut they would need some way of staying in place or a hexagon on the back of them to hold in place. As the OP states they need a nut on them I think they are just a 'Raised cup washer' as he states. These are for when the casting holding the stud of the trim protrudes through the panel for strength and the cup covers that allowing a nut to be fitted.
Cadillac used them extensively pre war when fender mouldings were die cast.
Same as these.
https://www.chevsofthe40s.com/detail/9667/Chevrolet_Trunk_Hinge_Washer_Cups.html
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
J. Gomez
Sorry folk’s long day yesterday..!  :(
Here is the link -> http://www.bobsclassicchevy.com/gm-body-washer-set-round-20-pcs-gm03.html
The original ones with the start shape hole may provide a grip once the washer-nut is tight, but these will do perfectly.  ;)
HTH
J. Gomez
CLC #23082
