1953 speedo cable question
Started by Steveabilly, December 19, 2016, 01:13:21 AM
Steveabilly
I have a 1953 Cadillac Series 62 sedan and it's never had a Speedo cable, it has a Chevy 350. My question is do I need a special adapter to make a cable work? Don't know anything about Speedo cables any help is appreciated.
Quentin Hall
I'm not sure about the ratio will be the same but most GM cables are pretty similar. You can normally get ones that you cut to size and crimp the end on. Try Napa.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
