1976 Eldorado power antenna help
Started by south280, December 08, 2016, 06:46:41 AM
south280
Hi All,   I would appreciate any advice on fixing my power antenna.   Here are the conditions:
When I turn the radio on/off I can hear a small electric motor running for several seconds but the antenna does not move.
When I use the dash antenna switch I do not hear the electric motor and nothing happens.
I can raise and lower the antenna by hand but when lowering the antenna it stops 6 inches from base.
what is my next step?  Thanks in advance  David
1976 Cadillac Eldorado Bicentennial Edition
1930 Model A Ford Station Wagon
1968 Mercedes 280 sl
