1974 Fleetwood Brougham Spare tire
Started by ithaca1230, December 07, 2016, 02:43:03 PM
ithaca1230
I need to find a rim and tire for the spare and have not been able to source one. Do you guys know what other vehicle I can use as a spare rim. Thanks
If you are just looking for something that will fit just about any full size RWD GM from about 70 to 96 will do.  Also 70-mid 90's 10/1500 2x4 trucks.   Earlier you run into the drum vs disc clearance issue.
Correct and hubcap will fit may be another story.   I don't remember did 74 have the locking wire caps that had the hooks that had to go through the slots?
ithaca1230
I have not pulled the wheels yet so I am not sure how the hubcaps are attached. I would love to have a original rim but have not been able to source one.
