1956 cadillac transmission
Started by alien poker, January 10, 2017, 12:05:10 PM
Rolls-Royce models till 1964 or something like that never used the Hydramatic installed on Cadillac models from 1956 to 1964. Rolls used the first Hydramatic generation.
Rolls actually ended up buying the design and tooling and kept building them themselves didn't they?    Was it because they didn't like the 'new' design?  Or maybe GM made em such a good deal that it made sense for them to have full control over the production?     I think I read in the early 50's there were years that GM sold more than they used themselves.     I wonder if that would have been the case if they didn't have the Buick and Chev transmissions that were different?
wbdeford
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
Did they then start buying 400's or go to something else?   I wonder if the design just hit a horsepower limit?
savemy67
Hello Rob,
The heaviest cars I could find that use a 700R4 prior to 1993 are the Cadillac Fleetwood Brougham, and Chevrolet Suburban.  How does the weight of these two cars compare to the weight of your '56 Cadillac?
If you decide to make the conversion, you will have a lot of work to do yourself, as others have indicated.  I tend to stick with the original engineering because it was mostly a holistic approach to building and selling a premium automobile.  I would argue that a competent rebuild of your Controlled Coupling Hydra-Matic will result in a reliable transmission, and save you countless hours of time, for about the same amount of money.  Good luck.
Respectfully submitted,
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
dplotkin
Quote from: CadillacRob on January 25, 2017, 10:16:56 PM
That price is through a friend who uses him regularly for old Rolls Royces (they also used that trans), and is his "cost" of hiring the guy.
Rolls Royce licensed from GM and built in England the dual range Hydra-matic. Rolls never used the Controlled Coupling Hydra-matic skipping it until the THM400 arrived for 65.
Dan
60 Buick Electra six window
60 Chrysler 300 F Coupe
62 Pontiac Bonneville Vista
63 Chevy Impala convertable
63 Ford Galaxie XL fastback
65 Corvette convertable 396
68 Chrysler New Yorker
