1940 Cadillac coupe rear window trim/molding removal
Started by Percy, May 05, 2017, 10:22:41 AM
Percy
Hi,
Can someone please tell me how you remove the stainless trim around the rear window. Is there a special tool? Trying to get the car ready for blasting. Is this the same for the windshield? I have the glass out.
Thanks for your help,
Percy
It has to be gently prized off. No easy way but gently. Find the join and tap with a wooden block.   In 41 it's fitted over a rubber seal. In 37 it is directly over the metal. Don't know what year they changed but many get damaged and replaced with a different screen rubber that does not require the chrome. Always sad to see it go.
Percy
Thanks Steve.
I believe it's directly over the metal for 1940 as the gasket is completely pulled out. I tried to pry gently but noticed it starting to deform so wanted to ask.
Is it actually stainless in 1940 Percy? My 36/37/38 cars are chromed brass.
Alan Harris CLC#1513
Guess they changed around 1939 then. Wish they had done it sooner as it's a hell of a thing to get chromed. Like trying to chrome a rattlesnake.
Brad Ipsen CLC #737
What really helps is to take a heat gun and heat the thing up.  There is tar between the stainless and the body so it has to be softened up.  If you bend yours up I do have these.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Percy
Thanks for the replies.
Good to know you have these Brad and the heat gun is a good tip. I'll reply to the thread and let the forum know how successful I am and if there's anything to be learned.
Fingers crossed!
-Percy
