1938 gear shifter
Started by Giff, September 24, 2017, 10:31:29 PM
Giff
Hey fellows ,I have to be realy be careful when changing gears or it will lock up,does anyone know the adjustment procedure or remedy?
You have to make sure the levers are correctly pushed on their splines and done up tight on the bottom of the column first. There's a special little tool for that but it can be done without it with two people. Then the levers to the transmission have to be aligned correctly. That procedure should be in the workshop manual.
The shop manual explains the procedure for adjusting. One is with the tool and the other is without it.
I have remade the tool which work well if you are interested.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Giff
Thanks John,got a service manual on the way.
