Vacuum line specs 69 coupe deville
Started by MH69Coupe, December 20, 2017, 03:59:24 PM
MH69Coupe
Guys,
I am replacing my aging line coming off from the thermal vacuum switch.
Is this the right spec? Or something I can use?
Any other recommendation or exp anyone wants to share please?
Inside diameter:   5/32" or 0.156 (3.96mm)
Outside diameter 5/16" or 0.313 (7.93mm)
Wall thickness 1/16 or .063 (1.6mm)
Dan LeBlanc
Snip off a section of what you have, put it in your pocket, take it to your local parts store, and say give me xx feet of this stuff.
Done.
Don't over-think this.
Dan LeBlanc
cadillacmike68
Right on Dan!
Now if someone wants the color coded Climate control lines, they can still get plain black and use a color paint marker from the local crafts store to pinstripe the line.
"Cadillac" Mike
MH69Coupe
Got it from autozone i think the lines from thermal switch needed a bit thicker one to stand the engine temp etc.
Thanks.
