74 Eldorado engine bay support braces
Started by danjarrett1, January 27, 2018, 07:42:03 PM
danjarrett1
While perusing numerous online pictures of early 70’s Eldorado’s, I have noticed that some of them have, what appear to be, structural support tubular braces that run diagonally from the top of the wheel well to center of the firewall in the engine bay. My 74 Eldorado's convertible does not have them, neither are there provisions, that I can detect, for them. I’m curious if mine were removed and never reinstalled? Or, were the braces optional?
1974 Cadillac Eldorado convertible
2007 Cadillac Escalade
1980 Cadillac Seville “Bustleback”
1985 Cadillac Eldorado
chrisntam
I had heard the convertibles did not get them but closed cars did.  Don't know the logic on that one, you'd figure it'd be the other around.
See if that's the case on the one's you look at and let us know what you find.
1970 Deville Convertible
Dallas, Texas
Mike Josephic CLC #3877
My 1973 Eldorado coupe has them.  They were not an
option and I believe your car should have them also.
Check the tops of the wheel wells under the hood for
screw holes -- those should be easy to spot.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
danjarrett1
Mike, as I mentioned, there are no provisions for braces, no empty holes on the top of the wheel wells, no empty receptacles on the firewall..it is as if they never were there! That’s why it’s a mystery. Can’t imagine that the convertibles were exempt but I can find no evidence that my car was ever equipped with them.
danjarrett1
Did a Google Image search on 74eldorado engines, none of the 74models depicted had the braces or struts! I saw the braces  In 71-73 models, but no braces the on 74’s, assume they quit using them after 73 becuase a subsequent search on 75-77 models showed the engine bay sans braces! Guess GM firgurered they didn’t need them any more
Maybe the braces made the front ends too stiff, which in turn could have been a compromise with regards to the crash collapsing ability of the front end?
As puzzling as it is, the closed cars have these braces and the convertibles do not.  Same on my 60 convertible and 70 convertible. Not there on my 76 either.
Seems backwards but GM didn't spend a nickel on anything that wasn't needed but this never made sense to me.
Brian
My '60 CDV didn't have the braces, but a friends' '60 Convertible does.
DeVille68
My 68 DeVille Convertible did not have those braces, but had all the holes and brackets. So if you drove over a bumpy road you could see the car flex by the amount the fenders would move and shake.
I then installed the two braces and the car or at least the body was much stiffer.
I doubt that it drives better or corners flatter, the fender just moves more in sync with the rest of the body.
#9
Have a look in that attached listing....There must be a reason why convertibles had no struts or different ones while closed cars had them...
DanishEldoradoFan
My 72 Eldorado Convertible has these braces, and is "born" with them.
Niels, Denmark
Your convertible should have them, according to the listing above. These struts are the same as closed coupes with radial tires while closed coupes with bias ply tires have different struts.
andysarcade
My '74 Eldo convertible does not have them, no mounts for them either. None of the 74 Eldo's I've been looking at online recently have them...
1974 Eldorado Convertible
danjarrett1
Thanks for confirming that!!  Don’t know why they discontinued it but I’m sure the engineers figured it out
cadillacmike68
It was probably a chassis change underneath that eliminated the need for them. My 1968 DVC didn't have them, but it has the holes and the studs sticking up from the fenders, so I added a pair. Now I need to paint them because they look ratty compared to the rest of the engine bay.
If your 60s convertible the optional Level Control, you Had to have them to hold the ridiculous vacuum driven pump for the rear shocks!
"Cadillac" Mike
