How to acquire a build sheet for my 72 Edlorado
Started by boseephuss, February 27, 2018, 06:31:11 PM
boseephuss
I am hoping someone is able to point me in the right direction regarding procuring a build sheet for my 72 Eldorado convertible.  Should I do any work, I would like to have it be factory correct for my car.  I have tried several places online, to no avail.  Thanks in advance for the help!
J. Sims
CLC Member #48960216
Mike Josephic CLC #3877
There is a way to authenticate your car using  a link
under the "Technical Section" on the Forum.
Unfortunately, it only covers vehicles through 1970.
I don't know of any other source that could provide a
"build sheet" for you.  Sometimes, there is a copy
"buried" in the car from the factory. One place is
under the rear seat.  No guarantees, but it's worth a
look.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Justin
I found mine in the springs of the rear seat back.
I'm still looking for the rosettes. I know they are here because I found one outer (moulded plastic) piece. Getting close.
jsanford
Jeremy
Sacramento, CA
1980 Seville
1981 Eldorado
2016 ELR
boseephuss
Thanks, I did contact them a while back but will use the online submission form now that there is one.  Thanks!
J. Sims
boseephuss
Quote from: "Cadillac Kid"  Greg Surfas 15364 on February 27, 2018, 09:03:29 PM
Justin
Thanks for the tip!  I appreciate you looking.
J. Sims
