Generator , Battery ?
Started by Bill Kaufman CLC# 15225, March 22, 2019, 11:31:37 AM
Okay Bruce, I have the small brown gen light wire from the VR wired directly to the new Alt.  Also the Alt is wired directly to the +bat with new larger wire. Everything is working great. The light on the dash is off. To test the light I disconnect the light terminal at the gen while the car was running but the light did not come on. I assume the gen has to fail and somehow ground itself to light the light.   Thank you for your help !  I now have bright lights and a very happy battery.
If you ain't Wrenching ...  You ain't Livin.  So get out there and Live a little..  !!
Current Labors of LOVE;
1948 series 62 Club Coupe / 346 L head / Rendon Blue
1954 series 62 Sport Coupe / 331 V8 / Aztec Red
1970 Deville Rag Top / 472 V8 / Nottingham Green
Previous Caddies ;
1969 Fleetwood Eldorado / 472 V8 / Wisteria
1974 Sedan DeVille
1993 SLS / White Diamond
2006 CTS / White Diamond
Quote from: Bill Kaufman CLC# 15225
I would expect GEN to come on with ign before the engine starts, go
off running.  good luck, Bruce Roe
