1977-1979 SEVILLE Engine Control Module
Started by Clyde Jason, April 05, 2018, 04:25:11 PM
Clyde Jason
Does anyone know where to find re-built a ECM or ECU?  Bendix has a part number of 1614448 and Im having a difficult time with this search.  I have a 78 Seville.
Quote from: Clyde JasonDoes anyone know where to find re-built
Below is my list of the ECUs and aps for the 70s EFI Cads.  Note a
couple different numbers are a direct interchange.  Probably a 79
with similar specs would be fine, also 79 Eldo, except the mounting
brackets don't fit a Seville.
Right, you can't really find these, and the ones you do find are
outrageously expensive, but may not even work.  I suggest you
send your defective ECU to me and get it repaired and checked
out.  I don't know of another repair facility.
Read about 70s Cad EFI on the first album of my PHOTOBUCKET
  http://s93.photobucket.com/albums/L71/bcroe/
  click on an Album
  click on a picture to enlarge + description
BRUCE ROE                                  bcroe@juno.com
5719 EAST SKINNER ROAD,     CLC # 14630
STILLMAN VLY, IL    61084-9215     Phone  815 234-8039
76-80 Cadillac Bendix ECUs  from Bruce Roe
Here is my list of early ECUs with application.  I
believe some more late models may exist which
came out after my source of info.
Additions or corrections, let me know.  Bruce Roe
Closed loop use an OX sensor.
E = Eldorado
K = Seville
C = full size rear wheel drive
Fed = 49 state application
Cal = California application
All = 50 state application
500 = 76 Cad engine
425 = 77-79 Cad engine
350 = 76-80 Olds engine
Orig = original part
remf = remanufactured or replacement part
Bendix #       car                    desc
160 7250  76 K Fed       orig 350
160 8339  76 E Fed       orig 500
160 8340  76 E Cal        orig 500
160 8341  76 K Cal        orig 350
160 8820  75/6 C Fed     remf 500
160 8822  75/6 C Cal/E Fed     remf 500
160 8823  75/6 E Cal      remf 500
160 8824  76 K Fed       remf 350
160 8825  76 K Cal        remf 350
160 8868  76 C Fed       orig 500
161 0814  77 K Fed       orig 350
161 0815  77 K Cal        orig 350
161 0826  77 K Fed       remf 350
161 0827  77 K Cal        remf 350
161 1163  76 E/C Fed    orig 500
161 1188  77 C Cal        orig 425
161 1189  77 C Fed       orig 425
161 1190  77 E Cal         orig 425
161 1191  77 E Fed        orig 425
161 1491  76 E/C Fed    remf 500
161 1875  77 C Fed        remf 425
161 1876  77 E Fed        remf 425
161 1877  77 E Cal         remf 425
161 1878  77 C Cal        remf 425
161 2079  77 E Alt          orig 425
161 2154  77 E Alt          remf 425
161 2305  78 K Alt          orig 350
161 2947  78 C Cal        orig 425
161 2949  78 K Fed       orig 350
161 2950  78 C Fed       orig 425
161 2953  78 K Cal        orig 350 open loop
161 4446  78 K Fed       remf 350
161 4447  78 K Alt          remf 350
161 4448  78 K Cal        remf 350
161 4449  78 C Fed       remf 425
161 4450  78 C Cal/79 C All    remf 425
161 5137  79 E Fed       orig 350 open loop
161 5139  79 E Cal        orig 350 open loop
161 5173  79 K Fed       orig 350 open loop
161 5882  78 C Fed       orig 425
161 5883  79 K Cal        orig 350 closed loop
161 6206  79 E Fed        remf 350
161 6207  79 E All          remf 350 open loop
161 6208  79 K Fed       remf 350
161 6209  79 K Cal        remf 350 closed loop
161 6210  78 C Fed       remf 425 After Vin 223335, must use with blue (500) injectors.
161 8498  79 E Fed       orig 350
161 8810  79 E Fed       remf 350
161 9550  80 K/E Cal    orig 350 closed loop
161 9551  80 K/E Cal    remf 350
7 Nov 03, 20 Dec 10, 25 Nov 2012
