60 Fender skirt
Started by Skwerly62, March 14, 2018, 09:34:15 AM
Skwerly62
I have a spare fender skirt for my 60. Friend of a friend has a 64 in need of one. Don’t want to steer him wrong, will the 60 fit the 64? Thanks!
1958 Extended Deck 62 Sedan SOLD
1960 Coupe - current project
USCG Vet - Fly CG!
Barry M Wheeler #2189
Even without a parts list, I can tell you that it will not exchange. This is a minor trim item and making a new one to match the contours of the body would just be in a day's work for the design team. There were several major body changes in those four years. Creases appeared and disappeared, everything would have been different. Sorry.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Skwerly62
Thank you Mr Wheeler! That’s what I thought.
USCG Vet - Fly CG!
Eric DeVirgilis CLC# 8621
1960 skirt interchanges with 1959 so hold onto it!
Bob Hoffmann CLC#96
Eric,
My memory says that's not correct.
Bob
David Greenburg
My parts book agrees that '59 and '60 are not the same.  Different part nos. for '59 and '60, as well as different part no. for '60 Eldo and Fleetwood. And the latches are slightly different; '59 latch can be easily operated by hand while '60 needs a tool.  Not sure why they changed it; maybe to make them harder to steal?
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Skwerly62
Thanks for the hearty discussion. I went to clean it up in the blast cabinet and it was FAR from restorable. Held together with fiberglass and undercoating!
USCG Vet - Fly CG!
