Exhaust manifold gaskets 365
Started by CadillacRob, April 21, 2018, 04:36:36 PM
CadillacRob
My gasket set came with exhaust manifold gaskets for my 1956 365.  I've heard mixed things, some say use them some say don't.   I'm leaning towards using them, question is, do I need to use any sealant other than anticipated sieze on my bolts?  Thanks
1950 series 61 sedan
1956 coupe de ville
G'day Rob,
The Gaskets are supplied because by the time an engine requires rebuilding, the Exhaust Manifold surfaces are no longer perfectly straight.
The Factory didn't use gaskets so that the manifolds could slip and slide as they expanded and contracted during the operating temperatures.
As for a sealant, this is not necessary, simply because of the above-mentioned slipping and sliding.
Ant, as for Anti-seize compounds on the threads, certainly use it.
CadillacRob
1956 coupe de ville
I forgot to mention that one thing people often overlook is the Manifolds have at least one bolt hole that is the correct size for the bolt, and the rest are oversize.   This is to allow for the "movement"
The normal hole holes it in the correct position whilst the rest clamp it to the head.
Bruce,
I respectfully disagree.
The 1956 From the factory came with gaskets.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Thanks Johnny,
I have chastised myself severely.
Quote from: The Tassie Devil(le) on April 22, 2018, 12:22:03 AM
Don't be too rude with yourself: you don't have the same experience with Cads from the fifties as other people!
