59 ignition switch
Started by 60eldo, October 07, 2018, 10:21:36 PM
60eldo
   I bought a 59 fleetwood and the ignition swicth is missing, plug is there. Is there any way of crossing wires to get it to the on position so I can check to see if lites pw are working.
Jon. Kluczynski
J. Gomez
Quote from: 60eldo on October 07, 2018, 10:21:36 PM
Johnny,
Just to do an “ACC” check you can place a jumper at the ignition switch between the “red” (+12V) and “yellow” wires for ACC position. Although the "ACC" just provides the +12V to the accessories radio, antenna, fans, etc. the lights e.g. headlights, interior lights, brake, etc. are all direct feed to the main +12V.
The “pink” is for the “IGN” position and the “violet/purple” is for the “SOL” position, you need to leave the +12V at the “pink” wire and tap the “SOL” as well if you need to start/crank the engine.
Also, you can do a Google search and find the wiring diagram for reference if you still do not have a Service Manual handy, although the Service Manual is a must.
Good luck..!
J. Gomez
CLC #23082
Lexi
Further to Jose's post, attached are 2 images of the 1959 Cadillac wiring diagram from the '59 shop manual. It would not scan well as it is spread over 2 pages so I took one overall photo plus one close up of the page that shows the ignition switch wiring and connections. Hope this helps. Clay/Lexi
Skwerly62
Johnny K I have an extra if you need one. No bezels etc though.
Chris
1958 Extended Deck 62 Sedan SOLD
1960 Coupe - current project
USCG Vet - Fly CG!
Daddio
SOLD - 1959 Eldorado Biarritz
60eldo
 No I dont need a switch, I bought a 59 fleetwood and somone hit the switch with a screw driver and hammer, i wanted to check all electrical. But I got it now to turn on with my screw driver haha thanks all, I want to part this thing out later and wanted to no what works
Jon. Kluczynski
