needle valves
Started by spolij, January 05, 2019, 06:44:12 PM
spolij
66 deville - are the needle valves, fuel and air adjustment, supposed to fit sloppy? Mine just flop around wheather they are closed or open. They also do not affect the engine much. as far as raising or lowering the low idle.
