Where does this go?
Started by spolij, January 17, 2019, 10:49:12 AM
spolij
I know what it is. I need a pcv vacume hose, which i cant find, But each time i search for it i see this t along with it.  66 deville Mine did not have it.
Cape Cod Fleetwood
I'll play... given the size I'd guess it goes from the PCV breather on the pax side valve cover going to the carb on one end and the air cleaner on the other.
And if you listen to me, you're nuts.  ;)
\m/
Laurie
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
spolij
Laurie Not! Walnut lol
49r I' look Thanks
