1975 fleetwood speedo light
Started by Rdtreur, April 15, 2019, 03:17:12 PM
Rdtreur
Hi guys, the light bulb for the speedo on my 2975 fleetwood is out... I looked in my 1974/75 shop manua how to replace the bulbl but it seems that it’s not in there :-(.
Do I need to remove the whole dash or is there a easy way?
Many Thanks, Ramon
R.D. Treur
Past caddy’s:
‘68 convertible ‘70 Eldorado,  ‘75 sedan, ‘75 Fleetwood
Cadillac Fleetwood
#1
Access to the instrument panel cluster bulbs is from above.  Remove the center section of the instrument pad, the part that contains the AC vents. Start by removing each of the four AC vents.  Three of the four AC vents have a nut threaded to a stud inside, the ones at each end, and one of the center vents, but I don't remember which.  The center pad section slides backward to clear the studs and can be removed.  After sliding rearward, be careful to disconnect the two-way connector at the map lamp to avoid breakage, or better yet, remove the two screws holding the map lamp and just allow it to hang by its wiring while you are working. Unplug the wiper/washer switch. With the center pad removed, you can reach over the instrument cluster, and under the top pad, to twist the socket/bulb assembly to remove, and change the bulb.  If memory serves, these are type "194" bulbs.  There is a bulb chart near the back of the owner's manual that will confirm the bulb usage.
Charles Fares
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
Rdtreur
Thanks Charles, very handy info again:-)
R.D. Treur
Past caddy’s:
jagbuxx #12944
Quote from: Cadillac Fleetwood on April 15, 2019, 03:30:41 PM
Charles Fares
It’s the center right a/c outlet along with both outboard outlets that need removal
Frank Burns #12944
61 Coupe Deville Bristol Blue
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
Phil Weber
I'm thinking the 75 model might be the same as the 76 . If so here is the service manual page from the 76 manual. Globes are #161 in black socket and #194 in grey socket.
Phil
Rdtreur
R.D. Treur
Past caddy’s:
