What are these pieces for on my '70 Fleetwood?
Started by J.C., May 20, 2019, 01:58:31 PM
J.C.
Hi, All!
I noticed these rusting pieces near my windshield around my windshield wipers; does anyone know what these pieces are called and what they're for?  Does anyone know where I could find that screen mesh?  I circled all the rusting pieces in red in the attached pictures...  All input appreciated!  Thanks!
J.C.
Coral Gables, FL
2023 Genesis G80 Electrified
2023 Volvo V60 Recharge
Robert LeCoque - #1283
The two strap like pieces are grounding contacts for the hood.  They ground the hood to the body.  The screen is the air intake for the Heating and A/C System.
R LeCoque
cadillacmike68
The hood is grounded to the body by the huge steel hinges.
I think they are supposed to hold your windshield washer lines in place - preventing them from getting all out of place.
"Cadillac" Mike
chrisntam
Paint the mesh, no one will be the wiser.  Perhaps some steel wool or scotch brite to clean off the rust first.
I'd heard those straps were for grounding something, perhaps w/ the radio.  I'll peruse the shop manual to see if it provides a tie breaker.
I agree the hood would be grounded via the hinges.
1970 Deville Convertible
Dallas, Texas
Cape Cod Fleetwood
John I have yet to find out what those hooks are for...
And that screen DOES NOT EXIST, be incredibly careful with it.
It will be very, very brittle.
I restored The Ark's cowl last year. Not hard but you have to be hideously
careful with that screen since it DOES NOT EXIST. Loosen the screws on the chrome trim
and the hookie thingies the wipers sit on. EVER - SO - GENTLY wiggle the screen from under
the trim and its also under the weatherstripping. Carry like a new born baby to your work area,
GENTLY remove any debris that won't dust off easily, warm soap and water for hard to remove
debris, let dry. Gently hang from somewhere and spray with semi gloss black paint. Now is your
chance to vacuum or blow out the cowl and repaint, semi gloss black. On that chrome, 0000 steel
wool and WD40 to remove any rust or stains. Let it sit for a bit then wipe clean. Polish with Blue Magic.
EVER SO GENTLY replace the screen, take your time, its very brittle and it DOES NOT EXIST.
You can replace all of those screws with these, don't laugh, they're a perfect fit and match/look great.
https://www.homedepot.com/p/Everbilt-8-x-1-2-in-Truss-Head-Phillips-Drive-Lath-Self-Drilling-Screw-1-lb-Box-270-Pack-116077/205142958?keyword=sku+295+543&semanticToken=22200100011_520782120082272_wlnx+22200100011+%3E++st%3A%7Bsku+295+543%7D%3Ast+sc%3A%7B295+543%7D%3Asc+cnn%3A%7B0%3A0%7D+cnr%3A%7B8%3A0%7D+cn1%3A%7B5%3A0%7D+f%3A%7Bb%7D+cnv%3A%7B1%3A1%7D+oos%3A%7B0%3A1%7D+rt%3A%7B295+543%7D%3Art+dln%3A%7B562938%7D+qu%3A%7Bsku+295+543%7D%3Aqu
After you've replaced the screen and the screws, pull the weather stripping back a bit and put a thin bead of DAP clear latex window caulking, this sort of glues the screen and weather strip back together and gives you a nice seal. Can't stress vacuuming or blowing out this whole area enough before paint/re-assembly.
Here's some pics of when I did The Ark's cowl. Take your time, be careful with that screen, it DOES NOT EXIST.
\m/
Laurie
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
Flyer
This wire mesh may still be available. I checked Amazon and they have a sheet 12" X 24" #10 mesh stainless steel for about $25. It would have to be cut to fit using the old mesh as a pattern and then painted. If #10 is the wrong size mesh other sizes are available. Laurie- great description as to what needs doing to fix he cowl, thanks. Hugh Dean
Jeff Rosansky CLC #28373
Little Jeff tip for when you are working on that area. Those grounding straps are sharp and can slice you so be aware.
Jeff
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Cape Cod Fleetwood
Quote from: Flyer on May 21, 2019, 08:32:13 AM
Thanks Hugh, a chance for me to give back to a forum that has given me so much.
\m/
Laurie
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
Cadillac Fleetwood
#8
My '70 Fleetwood Brougham does not have those metal pieces. It only had one owner before me.  I seem to recall that they furnished a ground for the windshield antenna.  I also seem to recall that in Cadillac literature (the Cadillac Serviceman, perhaps) that these were discontinued during the '70 model year, as being no longer necessary.  My Fleetwood was built during the third week of March (03C) and is body number 13418.
-Charles Fares
1969 DeVille Convertible
1989 Fleetwood
J.C.
Quote from: Cape Cod Fleetwood on May 20, 2019, 11:09:50 PM
Take your time, be careful with that screen...
\m/
Laurie
Thanks, Laurie and Hugh for the info!  I'll see what I can do with that part before the GN!  Again, much appreciated!
J.C.
The mesh Hugh mentioned is only 24" long, but the length along the windshield is probably closer to 5' or 6' (I'm not with my car right now, so I can't measure).  How would I attach the 24" pieces together so I'd have one continuous piece from one side of the firewall to the other?
J.C.
Cape Cod Fleetwood
Quote from: J.C. on May 25, 2019, 01:26:12 PM
J.C.
You don't. Its why you have to be SO CAREFUL with what you have. Be gentle, take your time, don't force it, wiggle gently. You'll be fine. Just remember the mesh is very brittle, be gentle. See my pics?
\m/
Laurie
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
chrisntam
#12
Several people are correct here, here is the page from the Cadillac Serviceman that speak to the pieces in question.
We have some very sharp and knowledgeable folks here!!!
8)
Dallas, Texas
Nice to read that they included a reason to omit the pieces, without simply saying that they are no longer required.
Daryl Chesterman
Hi John,
This is a possible source for stainless steel screen, if that is what you want.  You will have to determine what mesh you have, and match it in this website.
https://www.twpinc.com/wire-mesh-material/stainless-steel
A website that tells how to determine the mesh size of your screen.
https://homeguides.sfgate.com/determine-mesh-size-window-screen-25184.html
Daryl Chesterman
