'60 SdV tie rod joints etc
Started by pocale, May 23, 2019, 07:02:45 AM
pocale
Greetings from Finland, North Europe.
I am helping a friend; annual vehicle inspection was disapproved due to a few front end issues and rusted trunk floor.
Specifically
1) lower ball joints, that should be straight forward
2) right side tie rod inner end
    i found a pic where i can see it is a ball joint to tie rod
    how does it separate from the tie rod?
    i could not find a spare part for the inner end of tie rod, so i suppose there is a replaceable bushing in tie rod for the ball (how to replace)..
    or how do you fix a loose inner end joint?
3) idler arm loose to tie rod and free play up'n down at the bearing. for the tie rod joint  i guess #2 questions apply for the separation and bushing(?),
    is there a replaceable bearing, can it be tightened or a new assembly?
4) front brake hose cracked, is it strictly model specific or is there a more common car model hose applicable
Google finds only a few parts supplier, prices are salty (gotta add shipping to EU and local VAT too).
Where would you recommend to order from?
Help and experience shared is appreciated.
Thanks.
V8, A/T, RWD - other options are negotiable
If you want cheap parts, buy by Kanter. Be aware: cheap parts are always too expensive. Rare Parts is a supplier with good parts, unfortunately expensive. If you go to Google, you will find several suppliers, not only Kanter, for the cheap parts, usually made in China.
Daryl Chesterman
#2
Juho,
This is a picture from my Master Parts List (1956-1961) that shows the steering linkage.  The connecting link (also called a drag link) has repair kits available on many different classic Cadillac repair parts websites.  You probably need to disassemble the connecting link to see if any of the springs (group # 18.1405) are broken.  Unless there is a broken spring, the connecting link probably just needs to be adjusted on each end, where group # 18.1395 is located.  I don't have my shop manual here at the house, or I would give you the proper torque for those plugs.
If you have the shop manual, the torque specification is in there.
Daryl Chesterman
