What transmission lube weight for my 1929?
Started by Mike Baillargeon #15848, June 22, 2019, 02:52:34 PM
I want to change the tranny fluid in the 29 Roadster..
The old shop manual says use A-200 lube..
What does that translate to in today's weights?.......85W-90W??
Thanks for any help...
Baillargeon
#15848
Mike Josephic CLC #3877
Hi Mike:
The 80-W90 types were being phased in much later
than your 1929 car (mid 30's)  Your transmission
needed what was called a "Mobile 600 Lube" which
was thick and sticky lube.  The modern oils are too thin.
Here are a few sites to give you more information:
https://forums.aaca.org/topic/25135-600w-gear-oil/
http://modelafordclub.co.nz/wp-content/uploads/Just-what-is-600W-Oil.pdf
Engines by the mid 30's could use the more modern
oils but for your tranny you need these.  They are
still available.
https://www.amazon.com/MOBIL-600W-SUPER-CYLINDER-OIL/dp/B00G97EIJ2
Hope this helps,
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Baillargeon
#15848
harry s
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Thanks Guys.....you gave what to buy....Why to buy it.....and where to buy it...
I can't ask for more than that !
Thanks again...
mike
Baillargeon
#15848
Fed-Ex drop off the mobil 600 today...
I got it from Amazon which was $140 with shipping....
I think Grainger was $230...I don't know how Amazon does it but they do!
thanks guys !!
Baillargeon
#15848
I put the new cone spring in today, that I got from Pete Sanders.....
Then put 2 1/2 quarts of the mobil 600 into the transmission...
The shifting up and down the gears is noticeably better....even the old synchro's are working much better....
Baillargeon
#15848
Hi Mike:
Glad everything worked out for you!
2004 Escalade
Yes thank you Mike & Harry for the info....
Now I have to figure out how to pump this heavy lube out of the 5 gallon pail and into other transmissions and rear axles fill plugs....this tranny was easy I had the shifter cover off so i just poured it into the trans....
Somebody must make a hand pump to make it easy to fill thru the filler plugs on other rear ends and trannys....
Baillargeon
#15848
harry s
I used one from Harbor Freight with a hand pump. It worked OK but was slow due to the thickness of the lube and hard on the arm.     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Mike:
What you need is a hand held lube gun like this.
They were used for that purpose in the 20's.  I don't
know who still makes these but the photo is from
the Ford Model T site:
2004 Escalade
Classic
Gene Menne
CLC #474
Thanks guys....I'm going to take shot at the NAPA hand pump...
For 9 bucks I'll give it a try..... I can't imagine it will last long before leaking from both ends.....
I'll report back with results....
Baillargeon
#15848
I picked up that hand pump today at NAPA...looks ok...$9.56...inexpensive....
I put the bucket of lube out in the sun for an hour then tried the pump...
It pulled lube out of the pail....I didn't check to see if it pulled a full pint like it said on the box.....but it seems to work....It will be easier to then inject lube into the trans or rear ends..
Thumbs up so far....
Baillargeon
#15848
