1956 AM RADIO VACUUM TUBES
Started by RICHNICH56, July 30, 2019, 07:03:28 PM
RICHNICH56
Hello friends,
Does anyone know where i may find a vendor for the vacuum tibes in my 56’s AM radio? Part number?
Radio comes on with clear sound- for about 15 seconds then quickly fades away to silence. Turn it off and back on, SAME THING AGAIN! Ugh!! Can anyone help here? Thanks folks
novetti
Are you sure the problem is the tubes?
The Vibrator is the most common item to fail in these.
54' Iris Blue (Preservation)
54' Cabot Gray (Restoration)
58' Lincoln Continental Convertible (Restoration)
58' Ford Skyliner (Preservation)
J. Gomez
You also has some answers here as well since you posted the same topic on both  ;)  http://forums.cadillaclasalleclub.org/index.php?topic=156636.0;topicseen
J. Gomez
CLC #23082
Cadillac Fleetwood
It sounds like the rectifier unit, known as an OZ-4, is likely at fault.
-Charles Fares
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
Cadillac Fleetwood
Here are photos of the two tubes (both are 12V6), the rectifier (OZ-4), and the vibrator, which will be found in the power chassis portion of the radio.
-Charles Fares
1989 Fleetwood
