Flexible steering wheel on 39 Lasalle
Started by bariman, October 04, 2020, 02:49:21 PM
bariman
The build sheet on my 39 Lasalle notes an optional "flexible" steering wheel.  I assume this means the steering wheel with the 3 groups of 3 wire spokes but why is this called flexible?  I am often asked about this at shows but I don't have a good answer.
Does anybody know the history of this accessory?
Chris Cummings
"Flexible" steering wheel is what Cadillac called the "banjo" steering wheel a lot of moderns talk about.  It was an option in the mid-1930s, and a dramatic change from black bakelite or enamel-over-metal solid-spoke steering wheels.  Don't know more history than that.
Best regards,
Chris Cummings
I wonder if these were made to remove some of the shock that travelled through the steering components when travelling over rough roads, which were prevalent in those days.
las39
Quote from: bariman on October 04, 2020, 02:49:21 PM
Yes it's the 3 wired model that became standard in 1939.
1939 LaSalle 5027
1941 Chrysler Royal Coupe
1934 Oldsmobile F34
1976 Moto Guzzi Convert
las39
#4
Quote from: The Tassie Devil(le) on October 04, 2020, 08:22:14 PM
I think you're correct. And/or to bend and break off in an accident.
I never push the car by the steering wheel like on a modern one.  It will flex and break.
1939 LaSalle 5027
1934 Oldsmobile F34
bariman
LaSalle5019
"in those days"? You've not driven in Michigan recently.
