"New" to me '53 series 62
Started by Brett S, September 24, 2019, 01:27:33 PM
I'd say without a doubt that the coil is still the one that came on the car new.  ;)  Just a normal points and condenser system. The coil even had the resistor wire going to it.
Cadillac Fleetwood
Quote from: Brett S on September 27, 2019, 11:04:21 AM
What is the first picture? It say "inlet" on the top hard line.
That's the oil filter. There is a replaceable oil filter cartridge/element inside.
Charles Fares
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
gene harl
When  I was building my 51 , I found  the hyds. on it all shot and about $3000 to repair or replace ,, so off to the wrecking yard  I went and for less than 100 I got 4 elect windows out of some rice burner....married the elect to the hyds ,, been working great for about 5 years now,,,, if you want pictures, send me your email address ....
   Gene Harl     CLC22406      rgeneharlemail addresses not permitted
If that were an HEI the difference would be obvious and there would be no visible coil, that would be in the HEI cap.  The HEI distributor is much bigger.  If it has been converted to Pertronix just removing the cap will tell you that, there will be no points.  The distributor, cap and coil would be as original with Pertronix, the difference is the components inside .
mario
www.davessmallbodyheis.com
Very impressive conversion. Not cheap. Over 10 trouble free years of use on my 500 point dizzy.
Ciao,
Mario caimotto
wrench
#25
Quote from: mario on September 27, 2019, 09:11:00 PM
Ciao,
Mario caimotto
Great info, but in reviewing the website, unfortunately Dave got bitten by ‘a venomous arachnid’ and is pessimistic about his ability to continue...
If you are in the least bit squeamish, do not look at the pics of his hand in the gallery.
It is a very serious condition. I can understand his pessimism.
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
Brett S
I've been doing some research and have found that the newer Dodge Challengers use a hydro-electric pump for the power steering. From what I've seen online it's a newer version of the 50's Caddy. There's and Inlet and Outlet port on the Challenger. Think this could be used to replace the Caddy hydro-electric ?
Brett Samanns
Brett S
Well the motor seems to be locked up. I've got the cylinders filled with ATF now hoping it will break lose. If not, I'll be looking for another 331 before I make the LS plunge...
Brett Samanns
