1959 Cadillac 390 Water Pump Torque lbs.
Started by DeLoreanDMC81, November 02, 2019, 05:59:18 PM
DeLoreanDMC81
Hey gang. Just a quick question for you, and believe me, I try to find the answers before asking on here. And yes, I need to get a repair manual.
What is the specified torque for the water pump bolts, as well as the top inlet tube?
Thanks so much!
James
David King (kz78hy)
Here is a shot of the '59 service manual on the torque page.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
David King (kz78hy)
If you are on Facebook, checkout this post.  I made some studs to temporary hold the pump and gasket during the load process.   Remove each stud and replace w/the proper bolt and the gasket does not fall out of place.  Top Tip.
https://www.facebook.com/KeepemRunningAutomotive/photos/pcb.900240186774537/900239526774603/?type=3&theater
David
David King
CLC 22014  (life)
1955 Eldorado #277
2012 Volt
