1971 Coupe DeVille won't start
Started by V8marc, January 20, 2020, 07:04:18 PM
V8marc
Hello from Germany.
I have a 1971 Coupe DeVille (with Pertronix ignition) and it always started immediately. I had no trouble so far. However, this morning I started it and changed from "D" to "R" to reverse it. After this, the engine went off and ever since I am not able to start it again. I already did the following but nothing happened:
- Checked the battery.
- The engine cranks and produces a spark.
- Changed the spark plugs.
- Start pilot spray doesnt help either.
- Slight smell of fuel.
Any ideas? Maybe a lack of fuel pressure or a bad fuel pump?
Thank you guys!
Marc
’71 Coupe DeVille
Mike Josephic CLC #3877
I will not start since you shifted the tranny from
"D" to "R"?  Perhaps the neutral safety switch
has gotten out of whack.  Check it out.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
V8marc
Wouldn‘t it then crank in any gear or not crank at all? Neither one of this is the case. It cranks in P and N only but not in R.
’71 Coupe DeVille
G'day Marc,
If nothing else has changed, and you have spark at the plugs, and it cranks in P and N, then time to check the timing to see if the Cam Timing Gear has destroyed itself, as in the nylon teeth falling off, which it could have done a long time ago, and the Aluminium teeth have worn away, allowing the timing chain to slip.
One way to check is to remove the distributor cap and manually crank the engine via the crankshaft, backwards and forwards, and see how much slop there is in the rotor turning both ways.
You would be surprised just how well an engine will run in such a worn condition.
Mine still ran beautifully wit no nylon on the teeth, but way retarded.   Wouldn't have been long before the teeth were gone.
PS.   You have an email from the Moderators that requires your attention.
V8marc
Thanks Bruce. I will go and check it.
PS. I just completed my profile  ;D
’71 Coupe DeVille
Probably more like a bad Pertronix unit or coil.  If starting fluid doesn't get it to cough and there is a fuel odor it means to me that there is no spark.  At least check for spark at a plug wire.
Brian
#6
Quote from: V8marc on January 20, 2020, 07:04:18 PM
Hello from Germany.
Thank you guys!
Marc
If starting fluid won't at least make it try to run and you have spark as you said, then it would seem the engine has jumped time.
Based on the info we have so far I too am thinking next thing to check is timing chain as the others have described.  The all things seemed normal then shifted and it quit also fits.  Its slightly unusual you are not getting some pops here and there but it may have just skipped to the perfect spot where there just isn't any intake action or compression.   Where and how are you checking for spark?
These engines didn't come with a bolt in the crank and its not a common enough size that you can easily pick one up at a typical hardware store so you will most likely have to figure out a different way to 'rock' the engine than you would typically use.
SixDucks
 What size and thread is the bolt? Is it 7/16 fine thread?
Terry
1941 coupe
1962 Fleetwood
1988 Brougham
Previous:
1956 Series 62 Sedan
1963 Fleetwood
1975 Fleetwood Brougham D'Elegance
1989 Brougham
9/16" UNF.   Doesn't need to be too long, but 1" should be fine.   Don't forget to take the cork out, and if it is out, then it would indicate that the engine has been worked on in the past.
Or, the cork simply dried up and fell out.
V8marc
Guys
Thank you for your replies. I finally found the reason: somehow the fuel line going from the tank to the fuel pump was blocked. After cleaning it with compressed air, a big blob of dirt came out. Now she starts perfectly again :)
’71 Coupe DeVille
