1975 Eldorado fast idle question
Started by ChrisTabat, March 27, 2020, 10:08:46 PM
ChrisTabat
I have been chasing my tail trying to resolve a relatively minor performance issue with my 1975 Eldorado.    I have replaced deteriorated vacuum hoses,   and have the choke set so that it starts well both cold and hot,  and runs and idles smoothly at all idle speeds.   My issue is that unless the ambient temperature is 80 degrees Fahrenheit or more,  I can't get the first level of fast idle to stay off.   In looking at the choke linkage,  it looks like the choke has to be fully open for the fast idle to be completely off.  Any slight degree of closure engages the fast idle cam.   If I set the choke leaner, I solve the fast idle issue but cold starts are terrible.    My question is:  is there a way to adjust that fast idle mechanism so that it engages at more of a closed choke setting?    I have the shop manual and it talks about bending a tang on the linkage, but I'm not seeing how that will help.   Suggestions appreciated.
Chris Tabat #31293
'68 DeVille Convertible, '75 Eldorado Convertible, '71 Chevelle SS Convertible, '11 Camaro SS Convertible
Bella Vista, AR
QJ's have a fast idle adjustment screw "buried" in the choke linkage on the bottom of the carb on the passenger side.  It is also possible that the heating element of the choke has gotten tired and needs replacement.
ChrisTabat
Thanks.  Took off the primary vacuum break and found the screw.   The fast idle speed is about right;  it just won't come off.    Choke heater sounds like a good next step.
Chris Tabat #31293
Bella Vista, AR
Tpicks55
There are a couple of videos on youtube that show carb set up.  Just put i rodchester carb and you can see them. Good luck. Tony
94 Deville Concurs
2019 Lincoln Continental
2016 Cadillac XTS
If you are looking for a new choke heater / coil I would look for a NOS delco one.   Even 15 years ago the aftermarket replacements tended to be pretty low quality and unreliable.
