Does anybody make these in the aftermarket?
Started by ratpin, April 08, 2020, 12:43:12 AM
ratpin
The firewall wiring pass through bushings on a 1960.
Pictures attached
Cadman-iac
Steele Rubber has those. I think that OPGI does as well.
Rick
CLC# 32373
ratpin
Ive found this one, but it lists it for 55-57. Ill take some close measurements tomorrow and compare them.
