1966 Deville fuse panel pics?
Started by valeo77, August 16, 2012, 09:52:54 PM
valeo77
So I am getting close to being able to ride confidently but I am plagued by small electrical issues and I think it may have to do with the fuse panel. It looks like somebody did some mods and I am not able to tell what is correct. I have looked at my manual but the wire diagrams and key are very hard to read. It would be greatly appreciated if someone could snap a pic of what a proper fuse panel looks like.
The main issue I am having is my passenger window switch and all courtesy lights do not work, also my top blows a fuse every time I put it up or down â€" frustrating!
Thanks for any help you can provide.
Oh yea, my manual states that all verts and cars with power seats have a 40 amp circuit breaker, well mine has a 25 amp fuse in that spot...also leading to the mystery...
1966  Coupe Deville Conv.
PIC--->http://media.tumblr.com/tumblr_lxd1ejPFEn1r5r2vl.jpg
Sounds like you already know the problem. 20 does not = 40, and the circuit bre3akers are essentially "slow blow" to take the current for a brief while longer than a cartridge fuse.  Recommend you try correcting that problem first.  The windows in my '66 had a circuit breaker as well.
Greg
valeo77
After digging more I found out exactly what you are referring too here: http://www.summitracing.com/parts/rnb-85618/?rtype=10
To be honest I didn't know this existed! This is my first old car project and I am learning and enjoying every minute.
Thanks for your reply...
luchadorman
I know this is old, but I wanted to add a photo of the fuse panel from my shop manual! In case someone needs it in the future.
1966 Cadillac Sedan de Ville
