1949 Rocker Panels
Started by CadillacGlasses, August 18, 2018, 11:51:44 AM
CadillacGlasses
Has anyone restored rocker panels on a 1949 2 door? (either a coupe or a convertible) I'm trying to figure out if there are any reproductions that would get me started with the curved outers, but all the info on sites like Caddy Daddy and OPGI are really vague. Considering buying a 6ft 10in long sheet of 18 gauge and starting to roll it... which seems possible with some clamps, a long bench and some wood? Both inners and outers are rotted, but the outers were done really cheaply by the previously owner - attaching some photos
Thanks guys!!
M. Herbert
29645 - CLC West of Lake, CLCMRC Board Member
1949 Series 62 Conv. (in progress)
Joe V
Brad Ipsen CLC #737
The ones referenced above are the way to go.  Vary reasonable and the dimensions were right on.  Just did this a few months ago.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
CadillacGlasses
Great thanks! I just ordered two and will update you guys with how it fits. From the photos they look fantastic. Do you guys have any experience with any body brace replacements as well? I'm gearing up to rebuild the front and rears on mine from measurements I've taken. The whole front corners are rotted out unfortunately. Thanks again.
M. Herbert
FabCad
A friend is looking for a rocker patch panel for a 49 sedanette. I don't see any on eBay or anywhere else. Anybody know a source for these?
1948 Sedanette
1949 Convertible
1950 Convertible
1957 Biarritz
1960 Convertible
Jeff Maltby 4194
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
I suspect if you don't have a donor car, you'll have to fab any supports.   Once the NOS sheet metal is gone, it's not as easy as buying a collision repair part.
Can be tricky without the tools, some heavy gauge.   Make sure you brace and understand what you cut, before you cut, or you'll have a mess.   Always best to cut the least of the original as welding will allow.
FabCad
Thanks, guys. There are several manufacturers that make them for 50 and newer, but can't find any for 48/49. I guess there's not high enough demand-?
1948 Sedanette
1949 Convertible
1950 Convertible
1957 Biarritz
1960 Convertible
