Choke Setting and Adjustment?
Started by hawkfan, August 05, 2020, 07:46:44 PM
hawkfan
I'm trying to determine how to set and adjust the choke I have on my 4GC.  See the attched pics.  The plastic dial has a flat spot at the 12 o'clock position which locks into the slot in the choke housing so it cant be rotated.  I'm stumped!  I'm use to being able to rotate that plastic dial to set the choke.  I'd appreciate any input any one can offer.
Hawkfan
Saturnin15
The plastic cover won’t move.  You have to unscrew the screw in the middle and the you can move the small pointer.
Sedan Deville 1956
hawkfan
THANKS Saturnin15!!!  Much Appreciated!
