Bill Hirsch 1935-1948 Engine Enamel Green??
Started by Mike Baillargeon #15848, June 24, 2021, 12:38:01 PM
I'm cleaning up a 1935 LaSalle motor so I ordered the green engine paint from Bill Hirsch.....
Does this green look right?.....I envisioned more of a pea green, this is more forest green...darker than I thought it should be....
Also in the oil pan, I found what looks like a valve retainer clip....I haven't done a compression test yet.....I have the side covers off and the valve springs look ok.....maybe this is a previous repair that lost a clip?....do I have a problem?
Baillargeon
#15848
Poncholover
GREAT catch on that valve lock. Hope there is no damage.
Flattie Caddy
Tom Boehm
The Hirsch green is correct. I've seen the "pea green" on cars but it is not accurate.
Quote from: Tom Boehm on June 24, 2021, 10:26:08 PM
Thanks Tom,....I've seen that "pea green" on alot of cars and I thought it was correct...
Now I'm off to find out where that valve clip came from...
Baillargeon
#15848
