59 cdv throttle check relay
Started by Paul, August 07, 2021, 02:51:41 PM
Paul
Does anyone have any thoughts on the distance between the throttle relay and the throttle check valve? I'm trying to set it and not sure how far is 'in the ballpark' ? Right now it don't even come close. I'm referring to the device on the firewall. Thanks.
