hood hinges for a 1976 Eldorado
Started by Bill Levy CLC # 25695, September 26, 2021, 04:19:38 PM
Does anyone know if other GM hood hinges from the '75-76 vintage are interchangeable with the hinges on the '76 Eldo?
Your knowledge is appreciated.
B. Levy
41 61S Fastback
68 Sedan DeVille
68 Coupe DeVille
73 Fleetwood Brougham
01 Eldorado ETC
06 STS 1SG
V63
The hinges of all Cadillac 1975-6  (except Seville) interchange with 1975-78 Eldorado . I do not know about olds and Buick, but it would not surprise me.
Whats wrong with the current hinges?   Way back I spent a lot of money on NOS springs and having mine rebuilt and the corners still didn't pull down.   Read here that if the corners are not pulling down what you need to do is adjust them up.  Sounds backwards but it has worked on every car I have tried it on.   There is usually plenty of room in the 2 bolts and slots that go in sideways.  Sometimes you need some shims and or longer bolts for the ones more on the firewall that come down from the top.
chrisntam
Courtesy bump for my good buddy Bill.
Who's got a parts interchange list?
1970 Deville Convertible
Dallas, Texas
MaR
On the 71-78 Eldorados and 71-76 full sized cars, the issues with the rear of the hood not closing flush is with the rivets that hold the hood hinges together. When they get worn, they allow the linkages in the hinge to flex outwards which causes slack in the hinge. Since the spring is extended when the hood is shut, the outward flex results in the rear of the hinge flexing upwards. The only way to fix this is to replace the rivets. Changing the spring will only make it worst and there is rarely enough travel in the adjustments to compensate for the slack. It's virtually impossible to tell if a hinge is bad when the spring is on since the spring will take up all the slack. When you pop the spring off though, you will see that a worn hinge will have tons of side to side and twisting slop from the worn rivets.
Then a good machine shop should be able to replace the rivets? Or is this a specialty job where filling in the rivet pilot holes and then re-drilling them?
MaR
Quote from: Big Fins on September 28, 2021, 01:50:03 PM
On all the ones I have taken apart, the holes were fine. I have not found a place that sells the rivets and even if you could get them, they would be difficult to install. I made some custom stainless steel bolts for mine and they seem to work fine.
I know that there are differing grades of stainless, but isn't it too soft a metal to handle that sort of load? Would a milled Grade 8 bolt be better being turned on a lathe to create the needed shoulder and pivot surface on the bolt itself?
#8
There is a company in Derry, NH called SMS --- NO relation to SMS fabrics in Oregon.  They specialize in hood and door hinge rebuilding and did the hood hinges on my '73, came back as new.  Excellent work and I highly recommend them.  I would suspect any '70s vintage car that has seen some use would be a candidate for hinge overhaul.
https://www.sms-auto.com/
Bingo, using "Modify" after making the original post to post a link works.
MaR
Quote from: Big Fins on September 28, 2021, 05:01:32 PM
You want it to be a bit on the soft side. If you make them too hard, it will wear out the hinge linkages.
Quote from: MaR on September 28, 2021, 07:17:23 PM
Got it. So, then the pins become the sacrificial lamb.
Quote from: 35-709 on September 28, 2021, 06:49:48 PM
Good find Geoff.
KOKNEYELDO
Gents:
While on that subject, I bought a pair (75' Eldo) that had allegedly been overhauled and after a year the passenger side basically just buckled, which I had replaced.
When I took it back to the same place I bought it, the guy said (before I mentioned which side) he will replace it no problem.
So why only the passenger side seem to fail?
Present cars:
1975 Cadillac Eldorado convertible
1957 Ford Thunderbird
2007 Jeep Commander Overland
2018 Audi A3
Come On You Blues!
goob
I sent the hinges from our bicentennial convertible to the place mentioned about 5 years ago. They sent me a pair of someone else's used, as in not rebuilt, hinges. After phone conversations I sent them back and received a pair of hinges with loose rivets. Received another pair which are on the car but still not right. The car sits with the rest of the collection so I'm not too worried but the next set will be repaired 'in house'...
