...Speaking of electronic ignition...
Started by 71 Fleetwood, October 21, 2021, 02:00:37 PM
71 Fleetwood
I have a 1971 with a 472, stock ignition, wires and carb.  I'm thinking of converting to HEI (Davis Unified with the integrated coil cap) or Pertronix conversion with Flamethrower coil.  Both on existing distributor.
I have installed the D.U.I. from Davis on my Corvette and like it very much.  I have installed Pertronix on my Mustang and like it too.  I haven't used MSD products but I think they have a good reputation.
Does the 472 seem to have a preference that anyone has noticed?
1971 Fleetwood Sixty Special Brougham
Poncholover
The HEI is super reliable. If using Pertronics, it is imperative to keep the old parts in the glove box for on the road repairs.
Been thee, done that!
Flattie Caddy
dn010
Agreed to the "keep the old parts" comment above. One time I installed a pertronix with flamethrower coil (can't remember if I also put in a MSD ignition box) and it kept melting the rotor. I had to downgrade the coil.
-----Dan Benedek
'81 DMC DeLorean
signart
You remind me of myself at times...
"If it ain't broke, I can fix that"
Art D. Woody
Caddyholic
I run the pertronix it was on the car when I bought it. Been on at least 15 years no problems. Will the dui fit a 71 472? I think There maybe a clearance issue.
1962 Coupe Deville
I have a GM HEI Distributor on my '72, and experienced clearance problems with the AIR Pump crossover tubing.   It would appear that the engines that were factory-fit with the HEI used a different shaped tube.   But, as I was removing mine, it wasn't a problem.
Not all the AIR tubes seem to be in the way.   If it is in the way its only very slightly and only takes a slight tweak to make room.   The bigger clearance issue is with the dual belts.
If you get it timed in just the right place the belt just clears the main part of the cap but you for sure have to get it so one of the holddown nubs isn't pointing to the belts.  The factory solved that problem by going to a slightly wider single belt that was more in the forward position.
If you have no AC you can run a belt direct to the PS, there is even a factory part number for that.   Not sure how well a single narrow belt would work if you have working AC.
Cape Cod Fleetwood
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
71 Fleetwood
Thank you.  The HEI was a major pain to fit under the cowling of my other car but it ran perfectly.  I think I'll go with the Pertronix so that I don't mess with the AIR and belts.  My Pertronix on the 2nd car has also been perfect since the product first became available.
You are much appreciated!
If I am not wrong (I thought I w wrong once but I found out I was Mistaken) no one seems to have pointed out the difference between the Pertronics "breaker-less" ignition and the HEI.
Where as the Pertronics eliminates the points with a magnetic pick up it leaves the ignition system essentially the same.
The HEI be it factory, or DUI you have a magnetic pick up "feeding a solid state module then to an high output ignition coil.
Other than the difficulties involved with trying to miss the belts on pre-74 double belt motors, the end result with the HEI is far superior.
Lexi
Hey Greg, pardon my ignorance, but if you install Pertronix and also install the recommended flame thrower ignitor coil, would the differences between the 2 systems discussed be more or less consistent? Any comments as I am not sure myself. Thanks. Clay/Lexi
Cape Cod Fleetwood
Quote from: lexi on October 22, 2021, 12:30:12 PM
Clay The Ark uses Pertronix #1181 with the standard "factory" coil.
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
Lexi
Laurie thanks, I assume you are happy with it. Lexi also has Pertronix as well as the flame thrower coil. No issues. Was just wondering how that combination would  compare to what Greg was talking about, (i.e. Pertonix with just the OEM coil vs the HEI system he described). Clay/Lexi
FWIW the module in the HEI actually changes the "dwell" in direct relationship to engine speed, thus providing a bit of "fine tuning".
While I have used the Pertroniocs in my '66 with great success (always had a set of points in the glove box), and it provided a "waterproof" ignition system, I do not believe the Pertronics will continuously handle as high an output coil.
Big advantage of HEI is instant starting and long lasting plugs.
klinebau
I have had problems with the points ignition this past Summer and am seriously considering a conversion.  Apparently, the Pertronix 3 when used with the flame thrower coil can provide high energy spark along with multiple spark, adaptive dwell, and rev limiter.
I have had multiple condenser failures and attribute these to a possible bad/loose ground in the distributor.  I have since rebuilt the distributor, but if I continue to experience problems, I am going to make the switch.
Detroit, MI
71 Fleetwood
...Speaking of Plugs... :)  I am using copper spark plugs (I don't mind annual replacement).  With my other Pertronix and DUI the spark plugs are NGK platinum.  I understand that higher voltage = faster wear.  Do you think that the copper can handle 40,000 monstrous volts?
wheikkila
I have used Pertronix ignitions on most of my old 12 volt cars with little problems. I have always keep a set of points and condenser in my cars tool box. As far as the 6 volt, that is a different story. The nice thing about the Pertronix system is should if fail. It is a simple repair to get you back on the road. Not so easy if you have to replace the whole disturber on the side of the road.
             Thanks Wayne
Finndorado
When using Pertronix keep in mind to use that exact coil
which is meant for your version.
Pertronix 3 didn't work with my -73 500cid (hard start up +
one exploded muffler) so changed to Pertronix 2,
runs smooth now.
Finland
1973 Eldorado convertible
wheikkila
Yes, you have to purchase for the make model and engine that you have.
Thanks Wayne
Quote from: "Cadillac Kid"  Greg Surfas 15364 on October 22, 2021, 01:35:33 PM
G'day Greg,
Thank you very much for that intriguing explanation of the HEI Module.
Makes sense, or GM would have never changed the system.
I installed an Acell coil on the top of my HEI, but had to trim the cover so as to not destroy the hood lining.
The Race Tape is there to seal out any nasties, but it has worked so well that I left it.   One day I will plastic weld a nice cover in place.
