1953 Hydra Leak
Started by Larry Moss, May 05, 2004, 01:51:52 PM
Larry Moss
My 47 Cadillac has a 53 Hydra. Im leaking oil, and quite a bit when left standing. Question is how to read the dipstick. Should the car be idling,or at rest. How do I know when the trans is full? And, if full and leaking, what is the likely culprit.
Larry
Ralph
What ended up being the solution?  I have a 53 cadillac that is leaking as well.  I look forward to hering from you.
Jeff Maltby #4194
Remove the bottom flywheel cover-place a large piece of carboard on the floor under the flywheel-jack up the rear end so the tires dont touch the ground-fire the engine up then drop the tranny into drive and rev the engine. If you see a large spray pattern on the cardboard, you have a problem in the torus/flywheel area.
Jeffo
