Power steering/hydroboost
Started by Denise 20352, July 29, 2005, 03:31:54 PM
Denise 20352
  Couple of questions about Hydroboost.
  Did all models have it in 1976, or just CC?
  Does it take the same power steering pump as a car that has a vacuum brake booster?
thanks
-densie
Bruce Reynolds # 18992
Densie,
I wouldnt have a clue, but I have brought it back to the top for you.
Bruce,
The Tassie Devil(le),
60 CDV
Steve Preston #16375
All Eldorados had it and I think only the Fleetwood in other styles. Different power steering pump, its got 3 ports. Supply to the boost, return from the gearbox & a bypass for excessive pressure at the boost.
Plumbing is: Pump to boost, boost to gearbox, gearbox to cooling tube, through filter & back to pump. The bypass from the boost feeds into a port next to the supply port on the pump.
