lasalle trans?
Started by TROY SLAYBAUGH, January 04, 2006, 02:10:06 AM
TROY SLAYBAUGH
have a three speed trans number 58 on side of it inspection cover is on the bottem of it. with in closed drive shaft in great shap my friend sayed it was a lasalle trans can you help me troy in calif  if so email or call 209-604-7125 thank you
John Washburn
Troy,
Both Cadillac and LaSalle changed from floor shifers to column shifters in 1938.
So if you have a tranny that is not a top shifter, it will fit Cadillacs 1938 up to 53 when they last made a manual transmission. For LaSalle (same tranny) goes from 1938 to 1940.
If it is an earlier top shifter we need a little more info.
John Washburn
CLC #1067
Elizabeth, Colorado
TROY SLAYBAUGH
hi troy. about trany if any one needs one youcan call 209-6047125 thank you very much for the help troy
