Wrist pins in Cadillac 390 pistons
Started by Matt Innocenzi, June 16, 2008, 02:07:07 PM
Matt Innocenzi
Can anyone provide insight as to how the wrist pins are inserted into the pistons of Cadillac 390 engines?  Usuaully, wrist pins are held in with spring clips and include a bushing.  I have a 1962 Cadillac 390 engine and got new pistons, but there are no spring clips or bushings provided.  Were the pistons back then pressed in?  If so would that eliminate the need for the spring clips and the bushing that are found in other engines?  Any insight to this is appreciated!
Thank you!
Matt Innocenzi
CLC #21633
Matt I
CLC #21633
1958 Cadillac Sedan DeVille
1962 Cadillac Fleetwood
Jack Miller CLC# 24441
Quote from: Matt Innocenzi on June 16, 2008, 02:07:07 PM
Thank you!
Matt Innocenzi
CLC #21633
Matt,
I remember back in the mid 60's having to get my 283 Chevy wrist pins pressed, centered & set. I just looked at the service manual for the 1961 Cadillac and it shows the wrist pins being pressed in.
Jack
Jack
Matt Innocenzi
Hi Jack,
Thanks for the reply.  Engineering-wise how would this work?  What keeps the wrist pin from "walking" side to side and damaging the cylinder walls?  Also, without a bushing, wouldn't the forged connecting rod wear out the aluminum piston?
Thanks!
Matt
Matt I
CLC #21633
