1979 Gear ratio
Started by Paul Varcoe, August 02, 2006, 07:02:45 PM
Paul Varcoe
Can anyone give me the gear ratio for a 79 Deville?
Porter
How many times are you going to ask this question ?
  Re: 1978 Sedan Devile gear ratio
Porter
 Tuesday, 8/01/06 6:25 PM
http://100megsfree4.com/cadillac/cad1970/cad78d.htm TARGET=_blank>http://100megsfree4.com/cadillac/cad1970/cad78d.htm
Complete Thread
Subject Posted By Post Date
 1978 Sedan Devile gear ratio  Paul Varcoe  8/01/06 5:39 PM
       Re: 1978 Sedan Devile gear ratio  Porter  8/01/06 6:25 PM
Now you can give me a flame job and get my post deleted. LOL
Porter
Porter
Maybe this will clear things up, you originally asked for a 78 Deville rear end gear ratio.
1978 CADILLAC DEVILLE
Transmission: Turbo Hydra-matic transmission standard on all models; column shift.
Gear ratios: (1st) 2.48:1: (2nd) 1.48:1; (3rd) 1.00:1; (Rev) 2.07:1.
Standard axle ratio: 2.28:1, with 3.08:1 available
Hypoid rear axle
Steering/Suspension: variable-ratio, power assisted
Brakes: front disc, rear drum
HEI electronic ignition.
Fuel tank: 25.3 gal.
There are variables and ways to determine whether you have a stock gear ratio or an optional gear ratio.
HTH,
Porter
JIM CLC # 15000
07-06-06
Paul, Since you dont know if your car has the optional rear-end, You will need a buddy to help figure-out which rear-end your car has. I will suggest that you have on hand your buddys favorite brew( but dont pass it out just yet.( some of the work you can do before your buddy arrives to help ) Jack-up the rear so both rear wheels are off of the garage floor. Start by putting both valve-stems in the same position, and apply masking-tape to the drive-shaft where you can view it from out-side the car. When your dranking buddy shows-up, take him/her to the garage and have him/her turn one wheel while you turn the other. when you and your buddy have each turned your respected wheel one turn, The drive shaft will have turned either 2.28:1 or 3.08:1.  You will have to count the number of turns the drive shaft makes but that shouldnt be too hard.
HTH
Good Luck, JIM
Porter
Good answer Jim,
I learned something here, read something to that effect before but the plan has come together and another question answered, good job.
Im sure the vast majority of 79s came with the recommended factory gear ratio, sans the speciality vehicles with the optional one.
Porter
JIM CLC # 15000
08-08-06
Porter, I hope that you didnt learn that you dont break-out the brew untill the work is complete.
Good Luck, Jim
