54 55 56 Hoods -- Whats the difference???
Started by Bill Kaufman, July 23, 2007, 04:57:39 PM
Bill Kaufman
Howdy from Texas,  I have a 54 series 62 coupe that was in need of a hood. I found a hood off of a 55 sedan at the local wrecking yard . It was pretty beat up. It fits the car fine but the holes for the V Crest and badges are off a bit. I wanted a nicer hood before the car is painted so I purchased what I thought was a 54 hood from a local dealer. it turns out that it is a slightly different size from the other two hoods . I have been told that it is probably off of a 56.  Can someone tell me how to determine which hood will fit the 54 coupe.
Bill Kaufman
#15225
BILL KAUFMAN CLC#15225
Thanks Lou!   I looked at the pics and it looks as though the last hood I purchased was indeed for a 56. I could tell by  the badge hole configuration. that explains why it did not fit. hopefully the guy I purchased it from will have a decent 54 that I can swap for.  I know now what to look for.  Thanks again.                           Bill
Quote from: South_paw on July 23, 2007, 08:49:59 PM
Bill,
The 56 hood is not gonna work for sure. The front lip of the 56 hood is shaped differently when compared to 54,55 hood. Look at the following links to compare pictures
54
http://www.lidreamboats.org/andy1954.html
55
http://www.rrrclc.org/images3/HotRods_04%20(7)%20mod.jpg
56
http://www.lidreamboats.org/sitebuilder/images/mikes56fronttall-497x738.jpg
HTH,
Lou
Bill Kaufman # 15225   North Texas Region
1954 Series 62 Coupe
1969 Fleetwood Eldo
1970 Deville Ragtop
06' Harley  - (does that count?)
18 yr old cat and a fat German Sheperd with gas.
Remember, Those old Caddies and LaSalles where made to  BE DRIVEN !!
