Early Hydra-Matic Transmission Fluid
Started by Michael Brittan CLC #2750, March 31, 2024, 08:35:43 PM
Cadillac Jack 82
Personally Dex/Merc III work fine with the gals.  Had a hard shift in the 55 but added some Lucas and boom...gone.
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1964 Cadillac SDV
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
The ATF transfusion took place as planned.  The transmission took 12.5 quarts of the Dex/Merc, just like the shop manual says it should.  I have only managed to put a few miles on the car since.  My initial impression is that there is a small improvement in the 2-3 shift, but more extensive driving is required when time and weather permit. I'll report again when I have racked up some more miles.
M Brittan
#2750
Latest update:  After a few more miles on the road, my initial impressions following the ATF transfusion remain - i.e. a small improvement.  Tim's observation that Lucas treatment fixed the hard shift on his '55 is interesting, and may be worth trying, though possibly counterintuitive.  I would expect the Lucas additive to increase the viscosity (as per TJ Hopland's post) and therefore maybe exacerbate a hard shift.  On the other hand, maybe a slightly more viscous fluid might slow down the mechanical transition involved in the 2-3 shift and therefore be of benefit.  Any words of wisdom before I try this?
M Brittan
#2750
I don't think we know if the issues is its too thick or too thin for the hydraulic parts or if its too sticky or too slippery for the clutch and band parts so you just have to try both and see which helps. I think that is one of the interesting things about ATF, it kinda has to be all 4 things at the same time.
Upnorth
Hello Everyone I was just reading on here about the transmission to carb linkage Adjustment my 47 seems to shift at a slow speed
I was wondering if any one knew do I make the rod shorter or longer to increase the rpm the transmission shifts at?
Thanks Kindly Al
