Good day!
Purchased 2 months ago, Triple Black, 87 Brougham D Elegance here in MN. 21,000 miles! Factory memory seats, and front seat is stuck. Power windows, power lock, all work. Fuses checked. Found a mechanic to look at and he said their is a module under the drivers front seat. He found the part number GM20595050.
Quote: "Module has power and ground. Can move the seat by activing the switch. Control module has an internal failure."
Where can I find a new Module??? OR can a bypass of the system be done and I can live without no memory seats?
Can I just swap out the driver door seat/window/lock control, and have him re wire into the existing front seat, or does that all need to be pulled out and find a used "3 motor" power front seat?
Open for suggestions!!!
Try and disconnect the memory button switch on the door panel, the seat should function as regular seat.
