1959 CADILLAC DEVILLE BRAKE DUAL MASTER CYL CONVERSION
Started by 1969cadillac, August 16, 2011, 07:57:40 AM
1969cadillac
Hello - what is the easiest way to convert a 1959 deville single line brake system to dual ? is there a kit available?
thanks ,Murray Mules
Jeff Wilk
Just finishing one up now on my 59 Fleetwood.  Simple to do.  Midwest Power Booster out of IL supplies parts direct.  Tell them what you want to do and they will provide bolt on dual master.  Just be careful if you have Cruise Control.  You will have to simply move the Cruise unit forward by 2" by adding a simple piece of plate steel or aluminum and drilling holes to fit current bolts.  I bought mine at local home center.  Only other change is on one line to accommodate a dual cylinder.  web is www.midwestbooster.com  ask for Rich
Jeff
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
